As it is my job to fix these 'caravan pcbs' then I can tell you for sure the engineer is mistaken, or to be fair. mis-reading what he's seen, least I've been guilty of jumping to the same conclusion.
With the first very cold snap early Feb 2010 and a couple of 'strange' electronic failures, I'd indeed lept too the cold being the cause, seemed reasonable as we had not experienced such cold since before these boards were designed. Maybe they simply could not stand such low temperatures?
This last and worse winter I thought must, if I was correct, result in similar faults reappearing, not a single one!
One mechanical problem that have become 'prevalent' this year is Carver Cascade gas valves sticking open, I have changed more valves this year than in the previous twelve years!. I've stripped a few and can find nothing that might cause it, I really don't know but extreme cold is one possible.
Another is Carver's mk2 Fanmaster electric elements, quite a few of these this year have snapped, the metal is brittle so you can snap it as easy as a stick of rock!? Again not sure, but I've a feeling this may have something to do with cold, ie, they are known to become damp inside and if this damp were to freeze enough, it could easily break the element. Mind you, I've more thoughts on this as snapping is, as I said, far from unknown.
In short then, I agree with John's conclusion and any such apparent pcb damage caused by 'cold' is a coincidence
