Just discovered a fault in one window of my Avante. Window is approx. 1000mm x 500mm. By using fingertips, the distance between inner and outer 'pane' is about 1 to 2 mm and very light pressure makes them touch..
I assume the normal separation in the centre should be something like that at the edges around 13 - 15mm by estimation.
Questions
: Is there anything which can be done apart from replacing the window ? (My instinct says 'no' but I would like any opinions.
Although the caravan is still useable, what is the likely progress of this sort of fault ?
The van is less than a year old so presumably the window will be replaced under warranty. Is fitting such a replacement window easy ( it looks as if it should be) and how long should it take once the replacement is available - I would like to push the dealer into fitting it while i wait if the time should be around an hour or less)
Comments and advice appreciated
Questions
