- Jul 10, 2007
- 2
- 0
- 0
the issue is trying to get a cable through the bulkhead - i can't seem to find a grommet to use as the only thing i can find - high up- is a small cable [6mm?] on the far left [looking into the engine bay] high up and just before the drivers side wing. Can someone tell me specifically, where there is a grommet/hole to get through the bulkhead.
it was my dad's car and he has just passed away - i need to treat this car with the ultimate respect and care - there is no way i can risk damaging it in any way by drilling a hole "blind" in case i hit something the other side or add an "open wound" for rust to get in
As a compromise, is there anywhere i can "tap" a 35/40amp supply inside the car [not that im going to pull that kind of current but it helps with voltage drop to find a heavier than needed supply.]I'm not usually a person to compromise but in this case [see last paragraph] I would rather bin the caravan than mark the car in any way.
Has anyone tried running a cable UNDER the car? are there enough places to cable tie to? [can always protect it in a piece of hosepipe]
it's a deisel so fire hazard not so great but i'm not thinking of running along the fuel line.
Help! holiday looming!!!!
