I have a Avondale Perle custom in which the water pump does not work all the micro switches are ok and there are no water leaks so I think the pressure switch is not working wherre can I find it
James, how do you know there are no leaks if you cannot pump water into the van? rayJames, if you have taps with micro switches then you will not have a pressure switch. If you are sure that the switches are ok, [how do you know?],and that there is power getting to them then check with a volt meter for supply at the pump connection.
