AKS 1300/2004/3004 Hitchlock
AKS13L
This sturdy, colour co-ordinated security device is the essential accessory to prevent theft of your caravan. The device can be easily attached to the coupling/stabiliser by using the two specially handed mounting brackets. On the AKS 2004 these brackets are an integral part of the stabiliser body and are excluded from the kit. Once these are in position, the security device simply drops into the brackets and locks into place. Once locked, this device has been proved and tested to withstand a dedicated 5-minute attack test by Sold Secure. It has full TUV approvals and may enable you to enjoy insurance discounts from selected insurance providers. The AL-KO Safety also protects the bolt heads of your coupling or stabiliser, preventing theft of these expensive items!
The most obvious benefit of fitting the AL-KO Safety, is that you can keep the device locked-on whilst your caravan and car are hitched-up and whilst you are travelling. This removes the worry of 'guarding' your caravan when stopped at motorway service areas and also allows more valuable storage space in your caravan or car boot as it uses the ideal storage area - right on your caravan!The AL-KO Safety Anti-Theft Device is designed to fit the newer design of coupling head, the AKS 1300, 2004 and 3004 Stabiliser.
To identify which type of coupling you currently have, look at the markings stamped onto the coupling head if you have AKS 1300, AKS 2004 or 3004 then this lock is suitable.
