Hello Guys I thought that I would jump on here and ask for a little towing advice.
But first a quick intro.
We have had all kinds of Trailers in Canada ..... in Canada they tend to call them Trailers, in the US more so an RV.
Pop-Up Tent Trailers, 28ft Long Tow Behind Travel Trailers.
The one we had before moving back was the Smallest Fifth Wheel Toy Hauler that we could find @ 33ft long.
It was great unit that had a living area up front and an 8 x 10ft garage at the back.
We loved it but as we were moving home decided to sell it and the Ford F150 truck that we pulled it with.
So I'm used to towing but not used to our UK caravan.
It was bought in Jan and has been in storage since then.
it's an Abbey 420GTS with island bed - 2007 model.
I've bought a scale for the tongue weight and know that our Diesel Yeti can handle up to 85kg on the tow ball.
The caravan is well within the limits of our vehicle.
So providing that I keep all of the heavy stuff towards the front ... in front of the Axel ... and ensure that the lowball weight is no more 85kg ... should I be OK ?
How can you stop stuff sliding backwards in the van when rolling - does that happen often ?
I'd like to get a Power Mover installed and know that there are lots of brands now .... is there one in particular that you guys would recommend --- I'm in the Redcar area.
I'd also like to get Solar fitted as we will be doing a lot of camping at the Track with no electricity. The Caravan as apparently pre-fitted for Solar....not sure what that means. Can Solar Panels be roof mounted with needing to drill holes ? I've seen some reports saying yes and others no.
Also is there a Brand to go for ?
It is fitted with Al-KO anti-sway ... how often should those pads be checked & changed. is it any good ?
Same with wheel bearings .... how often should they be looked at.
Lot's of questions I know ..... any advice would be appreciated.
The caravans here are totally different here than back in Canada. Electric Brakes, different anti-sway devices etc..
However we are really glad to be home and looked forward to seeing this beautiful country .... once we get out of lockdown that is
Mick
Mick
