Hello everybody. I finally got round to fitting a Crystal winter kit to my Elddis Crusader Sirocco today, so I can use the van in winter by having the water barrel in the shower enclosure to prevent freezing. It was a fairly simple job-there were excellent installation instructions in the pack-and with a bit of careful measuring ("measure twice, cut once" I can hear my dad saying) and push-fit pipe fittings, the kit was in place and no leaks. I was careful to make sure that the wiring was consistent on each housing-the brown wires definitely run to the positive terminal on each housing, and the blue to the negative. I joined the two sets of wires to the existing caravan 12v wiring using a terminal block in what I thought was the right way. The caravan 12v supply at the main filter housing has a brown/green wire and and white/green. I believe the brown/green is the positive and the white/green the negative. On turning the water supply on, everything runs OK from either housing, but the pressure is less than I remember before the installation. The installation instructions refer to a possiblity of reduced pump performance if the pump wires are reversed, but I am pretty sure I've not done this. I removed the pump from the barrel and opened a tap to check the direction of rotation of the pump impeller-it rotates in the direction shown by the arrow on the bottom of the pump casing, and I guess it would spin the wrong way if the wires were reversed? Does anyone know for sure if the caravan 12v supply for the water pump is brown/green positive, and white/green negative? I don't have a wiring diagram for the Crusader. The other possibility is the extended pipe work may simply have reduced the pressure in the system-has anynoe had this experience after fitting a winter kit? Thanks.
