Removal of Sink in Pageant Loire
199
19,235
jondogoescaravanning.com
I have a Pageant Imperial which I think might be similar to yours. I've recently changed mine by disconnecting the drain. Undo the central screw whilst holding the outlet under the sink. Once the screw is out the outlet should pull away, but it may be stuck by the rubber ring. Use a blade to lift the four corner screw covers. Undo the four screws and remove the sink complete with the surrounding gasket.
