Hi,
I was wondering if anybody had ever fitted a radio to the above?
If so where did you mount it?
Great. That sounds like a good plan I was thinking of putting it in the cupboard wher the aerial comes down. Where did you put the speakers ?I retro-fitted a radio to a Bailey Ranger 560/2. Is that any good? I made up a plywood frame similar to the frame you might see in any factory fitted radio set-up (exactly the same as the one in my new Bailey Monarch) and covered it with patterned sticky-backed plastic with a design that was in keeping with the rest of the decor. All this was inside one of the overhead lockers so that when the locker door was closed you couldn't see it anyway.
I installed this on the side opposite the door so that I could fit a Ring aerial directly behind the radio on the exterior of the van. My present van has the radio door-side which means there is no point fitting an external aerial as you can't put it up if you are using an awning.
I took the 12v cable back directly to the battery (via an in-line fuse). Getting the cable through the back of the lockers needed a couple of small holes drilled in the dividing woodwork (once again, well out of sight at the back/bottom of the locker) and to drop down to the battery area I came down an existing piece of Bailey fitted trunking behind the curtains. Speaker cable was similarly hidden at the back/bottom of the lockers, through the same holes as for the 12v.
To get from one side of the van to the other, I took down the front curtain track and there was just enough room to fit a length of small trunking. The curtain track went back up and hid the trunking completely.
The finished result was very neat, even though I say it myself.
