Had to disconnect and reconnect the cabling on both sockets yesterday to replace the carrying bracket. Reconnected exactly as before and everything works except when I put on the right indicator the repeater buzzer sounds and the dash lights flash along with the indicator! If I switch the lights (side or main) on it works as normal. If I take out the green RH indicator lead to terminal 4 everything works as normal. Bit mystified and will go through everything later but if you recognise the symptoms, I'd love to know!
Thanks,
Steve
Thanks,
Steve
