Roof light removal/replacement
Nov 19, 2006
246
The roof light on my caravan has become loose-possibly when removing the caravan cover. The top piece is held in by two screws on either side and to tighten them it looks as if you have to remove the spring loaded arms which push the roof light up and clamp it down. Has anyone any experience of removing a roof light? Is it easy to remove the spring loaded arms?
Feb 28, 2009
493
Hi Morganic,
On the end of the 4 arms there is a screw in each arm which is screwed into the rectangular aparture sides. Remove these and the whole vent can be removed.
Some screws can be seen but on some vans there is a blanking cap which has to be removed first.
Hope this helps
Jim
Feb 28, 2009
493
Hi Morganic,
Hope this helps
Jim
oops........meant aperture
Nov 19, 2006
246
Hi Morganic,
Hope this helps
Jim
Many thanks. It all makes sense now. I will give it a go.
