Roof Ventilators
Feb 18, 2009
84
I have a Swiift Challenger 480SE. The insides of the Roof lights are very dirty and I was wondering if there is a way of taking apart the actual Roof Light. I have looked and think the arms that swivel must come off somehow but I can't see how. Any help would be appreciated with perhaps a photo. Thanks. Kenny
936
If you have the MPK rooflights, there are two small phillips screws holding each lower arm to the inner frame, possibly covered by a trim cap.
Remove the trim cap, undo the screws and the rooflight dome will come inside the van if it is rotated to come through diagonally.
Sep 11, 2005
67
I have had the same problem with my Swift but I could not remove them from inside so I removed the 4 screws that go through from outside on the roof using a plank across the the roof with some foam under for a cushion then you can wash the two halves mine are like new again. I did all three in about 1 1/2 hours
