steve
i,ve a lunar and the main large rooflight is a doddle just 2 plastic pins in the hinges to remove. needs to be in the open position to do it and an extra set of hands helps.
dave
Dec 4, 2007
7
Thanks for the advice guys.
I'm pretty sure that my roof lights are 400 x 400 MPK.
The only place I can imagine the screws are is behind plastic caps on the bottom of the legs of the pop up screen. I've tried to prise them off but they will not budge. Are these the ones you described John or are there other screws I cannot see? Just want to make sure I'm barking up the right tree before I go and break the thing in vain!
Thanks again
The 4 screws I mean are in the bottom of the legs and go sideways(parallel to the floor)into the frame side
You can then get the double skin top into the sink and give it a soak/clean/bottle brushing
Sep 30, 2006
208
Thanks again
Steve,
I have exactly the same problem. I can see the caps which presumably cover the screws but how do we get the caps off...like you I don't want to force anything. Meanwhile the rooflights are getting grubbier and grubbier!
Ron
