Round ceiling light switch
Feb 2, 2024
111
23
85
We just noticed that on the 2 round ceiling lights in our bailer ranger the switch has a l off and ll om it.whats this mean ? We switched between the 2 and the lights the same no dimmer no brighter so we're baffled
2,534
Some light fittings have dual light intensity, eg one bulb or both, so the switch will cope with that - and probably used as a common fitting even though only one bulb is present.
3,587
It may seem a strange question, but have you changed your lights from filament bulbs to LED's If you have then it could be the LED's are just too sensitive (which is a good thing for efficiency) They may illuminate fully on the reduced power setting of the switch so they don't appear to dim.
Reactions: breeze1470
Aug 12, 2023
540
234
1,135
I swapped same lights out with these get 18cm version. Literary night and day difference. LED bulbs were little better than originals but nothing on this new light.
Switching reading light bulbs to LED was cheap and made big difference. On my van porch light used same bulbs.
Just found this amazing item on AliExpress. Check it out!
NZ$33.24 | 12V/24V Ceiling Lamp Reading Light LED Touch Lamp RV Ultra-thin Round Dome Light for Caravan Boat Yacht Camping Car
