embecmom said:
Hi there, looking for some advice from all you caravan experts out there. I have a trailer which only connects to mains power. I want to run a small water pump (bought a shurflo) for simple sink setup. I have a line run to connect it (the pump) to the mains. Obviously as I found out, 12v from 230v no go. I dont want to put a battery in place as there is no room for it and I would have to run cabling for charging it plus to the pump.. I thought about buying a pump that could run off mains but cant find any small enough (i.e their either pond pumps or central heating! and way to powerful for what I need.
Is there a converter (transformer) out there that people are using thats small enough to use inline rather than again having to run more cabling plus it wires directly into mains or does anyone have an recommendations for under sink pumps off 230v (or is it 220v now)...it would have to be on demand/self priming i.e dont have to switch it on and off...
many thanks.
Hi ,
It should be possible to achieve what you describe, but what you have told us suggests the solution may be quite expensive.
You tell us you want the pump to be self priming. That means the pump will need to be a positive displacement type, that can generate enough vacuum to lift the water from its storage container. Most Sureflo are PD pumps and will self prime, these are often referred to as diaphragm pumps and there are a number of other manufacturers who produce equivalent products.
The downside is this type of pump tends to need a lot of current to start it running, Some of these pumps need a peak current supplyof 3 to 4 times their rated current to start them, and most conventional caravan supplies have trouble producing the necessary peak current to start these pumps. This is one reason why most caravans do also have a 12 v battery which acts as a current reservoir and allows these diaphragm pumps to be used.
Finding a 230v AC to 12v DC power supply with enough peak current capacity to run your pump is possible, but is likely to prove to be expensive. Such PSUs can be found on, on line auction sites, but be warey: there are vast numbers of Chinese manufactured Switched Mode units. They are mostly designed to run LED lighting, which has a benign power demand, asking some of these to power a pump motor which has a poor impedance and load characteristic may be too much even if the PSU has large current rating.
Generally water pumps run for short periods and relatively infrequently, so their daily power usage is surprisingly small, consequently running the pump of a dedicated battery as Hutch (EH52ARH) suggests does seem a reasonable proposition. You could also use a smart battery charger like the ones Aldi and Lidl sell to keep the battery charged.
