Satellite Radio
Nov 17, 2005
6
Is there anyone on this forum who knows.if it is possible to recieve radio through the satellite,without using a television reciever.If so what equiptment would be required.
Ray
938
You will need either a satellite receiver with a separate audio output or a suitable adapter cable between the receiver and your stereo. Often, you need the TV for an on-screen set up of the stations or to see which station you're listening to. But if you do that at home before you go and take note of which stations are on what channel you can listen to satellite radio without taking the TV as well.
Nov 17, 2005
6
Hi Lutz
Thanks for the info.I use a Pace Minibox and the only output is through a scart,So I will have to find a lead to suit my stereo.
Thanks again,
Ray
938
If you look around a bit you should be able to find a scart adapter for your stereo equipment.
