Shock Absorbers.
Mar 2, 2007
133
Hi. All. I have been reading the thread on this subject which ran in November in which most people were extolling the fitting of dampers. Whilst I have been towing for the last 25 years without problems, I feel that dampers could make the ride even better. I bought a new 13ft. Coachman last April, which is supplied without dampers as standard, and in May fitted a Model 3 Powrtouch, which Powrwheel say can be fitted to caravans with dampers. The mover is fitted in front of the wheels. My question is, can I now retro fit dampers with the mover in place?
Henry
44
19,185
The mover being fitted will be in the way of an otherwise 10 minute a side job, probably need 15 minutes a side then.
Worst case is if you need to slacken the mover bolts to move it out a tad to miss the shockers as the motor passes by, this then will take a little more time, best allow an hour all to together
