Hi there does anybody know how to remove the shower mixer tap on bailey senator Arizona series 6 water leaking from underneath the shower cubicle when water system is pressurized
Gralay its the panel that the tap is mounted on that is the problem it goes from the shower tray to the top of shower cubicle ive cut all the sealer it still doesn't want to come away don't want to break the panel ( thanks for the reply)I think that the majority of caravan taps are fixed in position the same as household taps with a back nut, so you would have to remove the tap from the back. However your leak could be due to a chafed pipe.
The shower is on the OSR of the caravan fully lined each side of the panel that the tap is mounted on no other access anywhere near it its right in the corner typical of a lot of bailey showers of that time 2008 (thanks)What is on the other side of the panel your taps are fitted to?
Is it a wardrobe or cupboard??????
On many caravans access to the shower tap is through a panel in the adjoining area.
Have you looked there?
Gralay that's the same shower as i said cut off all the sealer no rear access don't want to break it with pulling it to hard. Top and bottom don't want to move.The panel will be probably be glued to the wall and not needed to be removed to remove tap access to back nut of tap will probably be from other side of the wall
You seem to have 2 posts going on the same subject this 1 in technical and the other 1 in brand banter
I don't know how I managed to post on banter. Thanks for going to the bother of looking up the pictures of the showerOnly trying to help as to the layout and what the shower and tap was like as you said you didn't know how to post pictures. You seem to have 2 posts going on the same subject this 1 in technical and the other 1 in brand banter
