Silicon spray
7,983
Great for things that are sticking a bit like the catches on lockers. We use it often.
(Not oily like WD40)
In their wide product range WD 40 do sell silicone spray ........I've got an aerosol in the garage, but not at Lidl price unfortunately.
Reactions: Mel
3,930
Lubrication (awning rails, toilet cassette seals, window ans door seals......)
Graphite spray, to add to your confusion is good for door locks, as it PTFE spray, both dry to a NON oily lubricant.
Also great for lubricating your chain saw for when the damp in the caravan has gone too far, and you have given up the will to chase CRA 2015.
Feb 5, 2025
18
Lidl have the above in for £2.99. I. Have used this before and can't fault it.
Thanks for all the replies. I have a can of it that I use for the toilet and tank draining taps. Never having had an awning, I hadn’t thought of that option. Will bear it in mind. I thought perhaps there might be further uses of which I was unaware.
I certainly didn’t get it at the Lidl price, but it lasts years.
Oct 24, 2024
70
44
85
When I open my outside lockers, it says to periodically treat the rubber with silicone - do I just spray it on and rub it into the seal
Sep 23, 2023
910
331
1,135
I prefer a non silicone spray,the reason being if any paint work ever needs a repaint then it can be a time consuming job to totally remove the silicone,the result of contamination can be "fish eyes ..small bulbous circles" in the repainted surface,I use pledge or similar silicone free spray
Reactions: CrewOVtwo
3,907
If there is a chance of overspray reaching the surrounding paintwork, I would face away from the caravan and spray some onto a sponge , then wipe the sponge around the seals to transfer the goodness.
