Hi all,
Spent this afternoon going over our first caravan (Elddis) Shamal. The only item to give me concern was discovering that both rear pull handles are slightly loose. One a little more than the other. Oddly enough there is another Elddis XL model parked in the next bay to ours and(I'm sure the owner won't have minded me checking) it also had slightly loose handles both located in the same place.One far worse than the other.
Do I have anything to worry about? I hope not as we bought it privately. I have gone right through the van with a damp tester and the only damp reading was in the area of the floor vent near to the sink. I kept the cupboard cover open for a while, allowing air to circulate and a later check showed a clear reading. I presume it was condensation.
Is there some sort of sealant I can put around the handles to make them less likely to create a water ingress point?
Any advice would be most welcome.
