Hiya every-one, I thought this may be of use to you if you have the problem of the awning being too high for you to slide along in the rail on the side of the 'van.
I have made a gismo for me to do mine very simple to make and use, just a brush stale with a hook made from 6m/m dia steel bonded into the handle with epoxy resin. I have cut a screw thread onto the hook and then one in the handle and glued them together using the epoxy. (The threads are cut purely to give a greater gluing surface) I then covered the hook with shrink tube to give it a softer touch.
The hook is then inserted into the awning pegging down point and away you go. I saw a similar one used in the summer this year and it was a great success so I decided to make one for myself.
I amd now going to cut the brush stale in half and make an alluminium joining piece similar to the one used on snooker cues so that it will fit into the awning frame bag.
I hope all of that makes sense to you.
