Hi cris, your quite right its called "sleep apnoea" and the person only wakes up when they are so starved of oxygen the brain "shouts" at them to wake up,starts with snoring but the actual apnoea part is silent as the whole throat is closed off !!!!!!!!(hmm could it be anything to do with the pair of hands!only jokin) Tina xI take it this means you are keeping Frank awake Sue ;-)
Apart from buying a second caravan, a trip to the doctors if the person concerned has not already been.
A friends husband had quite a shock when after tormenting her and the family for about ten years he went to the doc and was referred to hospital for a sleep over and tests.
He was very very thankful that he had gone as apart from snoring problem being sorted he will live longer now !!!!
The bad snoring was linked to a condition where you stop breathing and kind of die two or three times a night :-( so the doc can be a worth while visit
This is not a Joke !!!!!!!!!!!!!!!!!!!!!!
That's the one Tina, couldn't put my finger on the name for once.I take it this means you are keeping Frank awake Sue ;-)
Those nasal strips that go across the bridge of the nose are good too, but not cheap and they make you look like Adam Ant.Not a cure, but try Boots'foam earplugs for a bit of respite. They do work!
Graham
