I have a small Maplin solar panel charger which I use to keep the leisure battery topped up when it is fully charged and in storage.I do this by using the crocodile clips provided but this meant I had to disconnect the battery from the van.I now need to keep the battery connected to be able to store my pre set radio programmes, but thats another storey.
I decided that that if I used the cigarette lighter connection I could use a cigarette lighter socket, fixed in the bed locker and run cables to the battery terminal clamps.
I have set this up, checked the voltage at the cigarette connector and when in use it is producing a variable voltage between 8 and 16 volts. This follows right the way through to the end of the 2 wires ready to connect to the battery quick release clamps.
When I connected the cables to the clamps and checked the voltage it was down to between 2 and 2.5 volts measured across the clamps but if I released any 1 of the 2 cables from the clamp the voltage shot back to the start voltage 8 to 16 volts. Reconnect back down to 2 to 2.5 volts.
Anybody any ideas why.
Many thanks
Hugh
Many thanks
Hugh
