lgvdriver said:
can I just use the twelve volt ciggy plug that comes with the panel to Trickle feed the battery.
You can but you may find that the feed from the battery to that outlet is only live when the master switch is on.
If this is the case then anything that your solar panel puts in will be lost due to other sources becoming live.
If i may be honest with you the size of panel you have will not even cover the natural dischage of your battery.
There is lots of information on this forum which will be of interest to you if solar is your future project.
It is all about managing your expectations and what you actually want to achieve.
As a rough guide you will need 10 watts panel per 100ah battery size, and that is just to overcome the natural discharge, in storage for example, in this country throughout the year.
So you will see that a 1 watt will not really make a difference, in real terms.
Even more so that any light will be defussed as it passes through a window you put the panel behind.
Mat
