Hi all, this is my first post so hope its ok...
i recently bought a Swift Challenger 470SE 1996ish, i got it very cheap as although it is in very good condition it has a spongy floor by the shower room.
Someone has had a go at repairing the floor in the past by drilling through the carpet and using expanding foam which resulted in still having a spongy floor but with big lumps under the carpet, i have pulled up the carpet and cleaned the mess up, and drilled out as much foam as i can:
I have 3 questions
1, i bought some floor repair resin and wooden plugs, will this resin expand when activated with water, I do not want the lumps back?
2, I would say the carpet is original by the way it is neatly laid under all off the cabinets and fixtures but on ripping it up I have found newspaper underneath which was a surprise, would Swift have used this method from new ?
3, How thick is the flooring, i do not want to go right through the floor, i have some drill stops but dont know what depth to set them ?
Thanks in advance
Dave
I have 3 questions
Thanks in advance
Dave
