SPRAY PAINT REMOVAL !! :(
May 1, 2008
CAN ANYONE SUGGEST A GOOD WAY OF REMOVING GRAFFITI PAINT FROM THE SIDE OF A TOURER CRAVAN ?
SOME NED HAS DECIDED TO USE THE SIDE OF OUR CARAVAN AS HIS OWN BLANK PAINT CANVAS USING STANDARD SILVER COLOURED SPRAY PAINT !
THX
Jul 31, 2010
1,285
Try T cut ( available from motorist shops) and gently rub in small circles, be careful as you may take all the paint off down to the metal.
Steve W
Aug 22, 2006
6
Would recommend that you use cellulose thinner first and apply the same as you would apply T-cut. This should dilute the spray paint as the spray paint is normally cellulose based. If this is not successful then i would move onto the T-cut.
Hope this helps.
Mar 26, 2008
873
If the spray paint has not been on the caravan to long or if you wax the caravan the paint is likely to come off using a power washer with the nozel close to the surface.
Do be careful near joints.
It worked on one of our cars, Bosch washer just blew it away.
Apr 6, 2008
71
Hello Mark
You can buy a can of graffiti remover spray[try the internet www.resapol.com]or your local DIY,just spray it on the spray paint and you will see it start to run and then you can wash it off.
