Hi Clive (the other)
It is a fact of life that ALL front engined cars will adopt a nose up attitude when the boot is heavily loaded. Most suffer from front wheel slip whether loaded or not. Though I do agree that heavy rear loading does detract from front wheel traction.
as you hint the reason is that the Centre of Gravity moves rearwards with greater rear loading, but at no time can the CoG move outside the extremities of the car, to do so would cause it to tip up!
As Lutz states, changing the attitude of a car with spring assistors will have a negligible effect on front wheel traction.
I know from experience with two Saab 9000's that they also exhibit this fact, But that is why most cars these days have dashboard headlight aim adjusters.
I have also had Vauxhall Carlton Estate that had pneumatic spring adjustor's factory fitted, but this was delux model and the basic models did not have them. As I recall the hand book made the point that the adjusters did not increase the load capacity, but did allow the car to ride at a more aesthetically pleasing attitude.
The only technical advantage that spring assistors offer is make the driving position better for short drivers. all other aspects are cosmetic.
