Starlink Mount
Just purchased Starlink WiFi for my caravan which i have on a seasonal pitch. As i no longer need the TV Aerial has anyone considered removing the aerial and replacing with Starlink Standard Dish but maintaining the through roof rotational mounting ???
Cheers,
Mick
The Starlink antenna is not a dish but a device known as a Phased Array. Once it is in place it does not need to be moved as the associated control gear can electronically steer the operating direction if it is ever necessary to do so. Ergo there is no need for the pole.
The installation comes with the brackets and mounts, power and link cables - all that you need.
If you move your caravan then the pole might be useful but you will need to talk to Starlink first to see if they can accommodate the relocation.
