Hi all,
I have a 2010 Sterling Europa with the on-board sureflow water pump. When running the cold water tap, the running pump will seem to throttle up and then throttle back in a regular pattern. The throttling back will slightly reduce the flow of cold water from the tap before returning to normal when the pump throttles up. This is not a major issue unless you are trying to regulate the temperature in the shower! Any ideas? Thanks.
P.S. I have also noticed the pump is a little noisy but I see from the Forum that other users have this too.
