swift challenger toilet
Apr 2, 2007
36
Hi i have a swift challenger 530se with an automatic toilet flush but have looked and cany seem to find where toilet rinse should go, there are no fill spouts in the cassette door and i know some of the models have a fill spout on them. its a 1998 model
2,564
There were many variations of the Thetford cassette - although it was possible to have electric flush with a header tank most electric flush fitments had no header tank so toilet rinse couldn't be added.
Apr 2, 2007
36
thanks for that, i was sure it didnt have one i have checked the manual from cover to cover, i have more question about other issues but i,ll post them later.
Apr 2, 2007
36
i also forgot to say it fill automatically when connected to water system, dont know if that makes a difference.
Dec 16, 2007
285
Hi There,
On our Challenger 500, the toilet flush water comes straight from the aquaroll, if the main water pump runs when you flush the toilet this indicates that it comes from the main water tank.
Hope this helps
Ian
Apr 2, 2007
36
Hi There,
Hope this helps
Ian
can you put rinse aid into yours?
Apr 2, 2007
36
Hi There,
Hope this helps
Ian
obv i know you cant put it in aqaroll, i just worded it wrong!!!
Nov 12, 2007
334
We had the same toilet in our 1998 Sterling Emerald. We liked the system and find now having to remember to fill the flush tank a real pain!
If you have no flush tank mounted on the wall behind the toilet, then you have no flush tank.
As you have no tank, there is nowhere to put the Pink rinse aid.It does not actually "fill" automatically, it just uses water from the Aquaroll as required.
The Pink is not essential. Even though we now have a flush tank, we still do not use it. Think how much you will save by not using Pink stuff!
