Swift Conqueror Toilet
Jun 1, 2008
98
Has anyone out there experienced the same problem as me with a Swift or similar. Everytime I take out the toilet cassette there is a water or "liquid" residue on top of the cassette and down the sides which in turn means that on each occasion I have a major clean up everytime I empty the loo!
It is the new type with the wheels and pull out handle if that helps.
It isn't a major problem at the moment as I wuld like to cure it befor it get's worse, incidentaly, the van is 6 months old
Feb 15, 2006
2,919
tom, i hate to ask this but when using it do you open the flap and wee down it or wee down it when its closed then open it?
we was weeing down it then opening the hatch we was told this was wrong as on all new van you must open the hatch then wee because of the problems you are having apparently.
good luck
jo-anne
Jun 1, 2008
98
HI Both,
Thanks for your reply, on a personal note I,m afraid that we tend to keep the slide shut and then open when finished, so to speak, so I never thought of opening the slide before and after so will try that method to see if it stops it leaking, but another pointer is that we use the headertank wih a rinse aid which we tend to leave in the bowl after use.
Tom
May 5, 2005
1,154
we leave ours closed with no problems,are you locking the casstte bit in position when you refit we didnt and had constant leak til dealer showed us.
Jun 1, 2008
98
The cassette goes into it's slot and then the handle clicks into place so I assume that it's in the correct position, and I would have thought leaving it open whilst using wouldn't be very hygenic
