Swift Conqueror
We have just purchased a new Conqueror and wonder how to stop items left on the fixed table at front of caravan from dropping down the back as there is a 2" gap and no lip on the table.. There is a radiator at floor level behind the unit so if anything drops retrieving it will be virtually impossible. Suggestions would be appreciated.
The gap is to let the heat rise from the radiator, so if you want to cover it I suggest some metal mesh (available at B&Q).
If yours is the new style pull-out table rather than the pull-out and fold over one, you should be able to fit a lip to the back edge.
how about slightly raising the jockey wheel so the van is very slightly nose high... we have a conqueror and i have never had anything fall down the front between the table and the binacle, as aready stated the gap is to allow hot air from the rad.
