Swift Milano 12v lighting issue
May 27, 2021
6
15
hi all,
I have a 2001 Milano. All Front 12v cabin lights have ceased working. Fuse OK. I'm thinking could it be a circuit fault. Would a failed bulb be the problem? Before I take everyone apart..... .. T.I.A.
1,859
6,935
Hi Traveller1
A failed bulb will simply mean one light will not work. It has to be somthing common to all of them, are they all off one switch? If so, perhaps the switch is faulty.
Reactions: Traveller1
May 24, 2014
3,687
763
A multimeter i thunk. Start at the bulb holder to see if you have a current. Then across the switch. If the other 12v lights are ok it seems it would be common that circuit.
Btw. Our very first van was a Milano 4 berth. Best van for quality we ever had. 2001 must have been one of the last ones.
May 27, 2021
6
15
Thanks all. There was a little "Switch" That I was told for the outside light (not working). When I went to check it, flicked the switch on. Hallelujah the lights came on.. :unsure::unsure:
