Tail light switch?
Mar 19, 2025
I have accidentally turned on the tail lights on my Adria Alpina Mississippi and now can’t turn them off!
I’ve read on a couple of sites that they can be turned on whilst parked but the manual doesn’t give any information, can anyone help? Thanks
Sep 23, 2023
1,169
471
1,435
That's a pity,,it would of helped,by tracing the wires from the lights it may of shown a switch in the circuit, also some switches are rotational but can be pulled out,fitted to many vauxhall/Opel of yesteryear,turning the switch operated the running lights,if pulled out just side lights operated,good luck..
Gary
May 30, 2024
81
90
635
Hi Glenn,
I did a bit of searching and found a couple of comments on this, including puzzlement from other Adria owners and extra puzzlement from others observing Adria caravans on site at night!
Looks like a couple of possibilities - maybe this video helps (leastways when the guy shows the tail light switch about 50 seconds in)
View: https://www.youtube.com/watch?v=XLng3qeYGbc
Then someone with a different spec control panel said that the tail light switch function is found in the control panel settings under AUX
Hopefully one of those helps,
Andrew
