Tap Cartridge repair
May 27, 2020
27
8
535
Afternoon all
One of our mixer taps is leaking and seems to be coming from the bottom of the tap.
Watched all the YouTube videos I can find and armed myself with the tools to find this (see attached). No metal nut in sight unlike every YT video I've seen.
I'm now completely stuck. The plastic bit doesn't seem to want to move in either direction and worried about using force in case it snaps.
Any ideas warmly welcome!
3,567
What exactly are you trying to do? Remove the entire tap or merely fit a new cartridge? My experience says cartridges aren’t very successful. A whole new tap from Screwfix is cheaper and more successful in the long run.
Jan 19, 2002
1,497
419
19,435
By the appearance from your photos your water system is with microswitched taps rather than a pressure system - the two wires connecting the tap control to the 12v pump system. It may be why the fitment is different to the expected with a brass nut to hold the cartridge in place to allow the passage of the wires. similar appearance taps seem to start around the £20 mark to operate the pressure system,, but the individually switched rather more expensive. You can check this by seeing if the wires under the taps in the washroom basin or the kitchen sink are connected to anything! If you post some details of the van and year then others may also be able to confirm this for you.
936
The days of makers fitting different taps depending on the micro or pressure operating system stopped a long time ago.
They all fit taps with microswitches, whether they are used or not .
Jan 19, 2002
1,497
419
19,435
Out of interest we still do not know how to remove the cartridge in the tap in the photograph, but if a replacement tap ends up being needed then some on line sellers specifically state 'for pressurised systems - not microswitched'. So I thought it best to check what system Thematrix has in the van!
936
Yes that is true, and taps used in caravans are the same as those used in other leisure items, and some of them do not use the same system as caravans, but UK van makers opted to fit taps with the micros because it saves time and stock to have just one item, and of course not to confuse the people fitting them!!!
Personally I think that the microswitched system is just another part to go wrong and having one switch on the pressure system is much better.
