thx for reply,i can see the flap not doing its thing, the lever is all the way over which normally closes flap,the dial that operates flap is probably in the open position which stops cassette removal.Welcome Kevy.
Are you sure its broke?
Have you checked the aperture inside is fully closed, actually stopping you from removing the cassette.
Just a thought.
yep,all that good, i think the mechanism that operates flap is in open position,stopping cassette removalIs the bowl turned enough to allow the cassette to slide out. Mine had to have the bowl correctly in line with the cassette withdrawal direction. It was quite sensitive tobalignment.
Hi,can,t find a model# anywhere,knob not being longitutinal is the problemIf you search for the Thetford Cassette Repairs for your specific toilet model there are illustrated clear instructions for a lot of things - maybe you will find help there - or help other responses from the forum if you could identify the model of the loo in question. It is likely that the loo hatch has to be fully closed so that the control knob is facing longitudinal to the cassette to enable the cassette to be withdrawn. It should be a matter of sliding it out without any resistance.
Model is C200Hi,can,t find a model# anywhere,knob not being longitutinal is the problem
Having suffered similar problems and corrected it with a simple fix, I wrote an article for the Tips and Ideas column on the Suffolk Centre of the Caravan and Motorhome Club.
Just Google Suffolk Centre Tips and Ideas and once the list is there look up Tip No 50 .
there’s a lot of different Tips and Ideas I put together over the years.
good luck
I need to remove the bowl on my thetford C200,does anyone know where i find the bowl retaining brackets? TIAThanks for the link Tintentman, very iteresting and helpful .
Sounds similar to the C260 that I have.there should be an orange knob I think with a slot in it,If you can maybe slide a long thin blade like a 2ft steel rule and try tap the knob through 90 deg.the knob being at the back near the slide opening,maybe open the emptying cap to release pressure might help.You can get spare parts from prima leisure or even a freshen up kit ( complete new cassette )Model is C200
