Can anyone tell me how to remove the rotating bowl on our S6 Bailey Indiana.The silicon has failed on the shower tray and access to reseal it would be much easier if the pan is not in the way.I was also thinking of rebating some upvc 6mm strip to overlap the joint as it is only less than 2mm and difficult to get a smooth fillet on it.I removed the screws on the front section of the tray and filled it with silicon then replaced and tightend the screws smoothing the squeezed out silicon.Is there a better way?
Many thanks.
Many thanks.
