Hi all when i was away this week i noticed my thetford full light wasn't working. So I didn't know when the holding tank was full (not very nice) Has the indicator failed and i need to buy a new one, or have i just knocked it and not illuminating?
Thanks for the advice i'm going to look now, i use thetfords own chemicals but all seem to breakdown fine when emptied but the light just wont illuminateSirRogerFFS said:Hi Abbey Owner this seems to crop up often now what I suggest you do is open the slide on cassette look carefully inside at the rear of it you will see a small float just inside like the sort of thing in a toilet sysytern you wont see any magnet but what you may well find is loo roll wrapped round it.This suggests that the chemicals in the casssette may not be strong enough or you could be using a loo roll that the chemicals cant mulch down.Also if you have ladies using the caravan loo do not let them use toilet wipes as this do not in anyway desolve. Had this time and time again but I think her indoors has got the hang of it now . I hope this helps .
SirRoger
the float is free, not filled with water will probably try and see tomorrow if the light works (hopefully) thanks for the helpSirRogerFFS said:Abbey Owner Once you have made sure the float is free replace cassette and fill with water from the inside of caravan and see if the light will come on.
Sir Roger .
Will probably try that, other options haven't worked even when the cassete is full of water no light has come on.Clive-Cardiff said:As you look in the cassette door, on the left hand side is a small plastic box. This contails the reed switch that picks up the signal from the float magnet in the cassette.Pass a fridge magnet close to the box while someone checks the led inside the van. If the light comes on then your fault will be inside the cassette.
