Thetford oven glass lids come loose
Jan 31, 2018
1,783
850
5,935
Just a note to check the grub screws are tight regularly as they do loosen and people find the glass lids on the floor after travelling. Ours in our Bailey Pegasus did this and have seen a lot of posts lately saying it was on the floor. I have strapped it with a luggage strap but yesterday used some clear silicone to save me the bother. Let's see if it works.
2,485
Good call.
A further warning. Don’t put canned goods in the cupboard above the glass lid. I can vouch that it breaks into 10,000 (approximately) bits. Finding it for years.
Reactions: JezzerB
Mar 27, 2011
1,332
507
19,435
Good advice, we are due to go for a short break on 1st October so I doubt I’ll be over to storage before around 26th sept So I’ve put a daily reminder in my phone from the 25th to check the grub screws, not something I’d enjoy clearing up, thanks for notification.
BP
Reactions: JezzerB
PTA
Mar 5, 2020
429
267
10,935
Interesting !
I have a new (2020) Elddis Crusader Mistral. All was fine when we had a short break in late June. However, after towing from Bilbao to Salamanca we opened the door to find the glass lid on the floor. We contacted a friend and he told us the same thing had happened to his (2020) Crusader. Luckily no damage was caused to either caravan.
As stated , check those grub screws on the hinges!
Reactions: JezzerB
8,504
You would really think that after all of mankind’s advances over millennia it would be possible to keep a oven lid in place. This isn’t a new problem so clearly the manufacturer has no inkling as to the performance of their product.
Reactions: JezzerB
Mar 17, 2020
521
382
11,135
Lid on floor too. Some distortion of the metal frame but "bendable back".
It's difficult to know just how tight to screw the grub screws - visions of breaking the glass.
JezzerB's use of silicone is something I'd not thought of but, I think, a great idea. thanks for that.
Edit to change "off" to "of"
Reactions: JezzerB
8,504
A small dab of clear Fernox leak sealer will retain the screws, or some loctite thread lock, but not stud lock.
Reactions: JezzerB
Oct 3, 2013
890
90
18,935
Hello,
Our Thetford stove glass lid blew up when we close the lid onto a ring that was still on (stove didn't have a gas cutout fitted.Never had a problem with cover coming loose.
Mar 17, 2020
521
382
11,135
That's as maybe Clive.
But doesn't alter the fact that you have to risk over tightening the screws and destroying the glass I'm afraid.
I suppose you could argue that if you've judged the tightening ok then your idea would at least preserve it! lol
Fortunately (touch wood) mine has stayed in place so far.
Now - how about loctite and silicone? :rolleyes::rolleyes:
Jan 31, 2018
1,783
850
5,935
I did belt and braces and put silicone in the grub screw threads too. Should be enough to stop them moving.
8,504
The Fernox goes onto the screw thread prior to tightening " or Loctite" , otherwise I would have advised using Duct tape, or putty across the screw heads.:eek:
4,240
I found that after my last tyre changes, when i had both wheels balanced, a lot less internal doors were open when arriving on site.
Jun 26, 2017
445
17
10,685
Which manufacturer are you referring to Clive, the manufacturer of the oven or that of the caravan ?
4,240
The microwave cooker is where our 12 eggs travel,, cupboard door over it, so double secure, but have to remember to remove any left when we get home. They can hum if left for 8 weeks. 😫
  • Haha
Reactions: JezzerB
2,485
Hi Beachball,
Our microwave doesn't have a cover do you mean the rotating glass plate.
The instruction for our van advises against travelling with the plate in place.
I think that Beachball ‘s has a plastic surround at the front to tidy up the gap at sides and top.
Reactions: JezzerB
