I have one of the above machines which has the grass strimmer, hedge cutter and chainsaw attachments but recently it has been playing up and refuses to start or runs for a short time on low revs but cuts out when the throttle is applied.
After spending some time eliminating various possibilities I narrowed the problem down to the carburettor, but spares for this machine are simply not available so thought it was destined for the scrap heap.
However, I came across another carburettor which looked like it may be a replacement so ordered one and it arrived today.
The changeover is very simple, just had to take the throttle cable bracket off the old carb and fit to the new one, just 2 screws, then slide back on the original fitting and bolt down refitting the air filter and reconnecting the fuel lines.
The new carb has its own priming bulb so the old one was removed.
Filled with fuel, primed, 3 pulls and it fired up and runs much better than it did originally.
For anyone who has the same machine and has problems, this is the carb that will replace the old one and bring your multi tool back to life.
Beehive Filter Replace Carburetor Carb for for Troy-Bilt TB575SS TB590BC TB146EC Walbro WYL-19-1 WYL-19 WYL-229 WYL-229-1 Shindaiwa T230 T230X T230XR-
