Sep 28, 2009
14
hello im trying to locate the fuse for the cassette loo on my 93 swift challenger 510. i was told its where the toilet cassette is but cant see anything like a fuse.do i have to remove any plastic covers inside the cassette space to get to the fuse. any help gratefully app.steve
Jul 15, 2008
3,751
848
……..remove cassette and get down low on your knees and in the roof of the chamber at the back, you will see the plastic back of a blade fuse usually 3 amp.
If this is not blown its connections may be corroded (white film)…if so spray with a product such as WD40.
If this is a new to you caravan and the fuse is missing you will probably need an experienced person to show you where a new one should be fitted!
Sep 28, 2009
14
ok will do. i did look and all i could see was an electrical connector onto a terminal. there seems to be a plastic cover held on with 3 screws which i undid but the cover wouldnt come away. the toilet did work so there is a fuse. im probably not looking to far back enough. many thanks steve
