Tow bar Data Plate
Apr 20, 2009
5,621
1,025
Where exactly is it, just had a quick look to double check my nose weight to see if it states actual nose weight, couldnt find it.
Leading on from another post on here I decided out of curiosity to double check, and to be honest think I have got it totally wrong!
Please could someone help clarify:
Authorised weight of van 1250kg
User payload 225kg
Total 1475kg
Nose weight calculated @ 4% = 59kg ??
This seems really light to me and to be honest will really struggle to get down to that level unless there is more weight further behind the axle.
G
Guest
You should have a manufacturer's plate that gives the maximum noseweight. It may be hidden inside the gas locker if not on the A Frame. What is the make of van and someone with a similar one may be able to help.
The usual noseweight is around 75-80 kg
Apr 20, 2009
5,621
1,025
Scotch Lad,
1995 Abbey Stafford
will look in the locker tomorrow, thanks for that.
James,
I was actually with you, used that figure for last two years!!!
But if you look in towing Law, fed from the homepage on here it clearly states 4% and that is why I'm questioning it myself.
Apr 20, 2009
5,621
1,025
Just copied this from towing law and it states Should be 4%
Noseweight
It is a legal requirement that the noseweight should be 4% of the weight of the trailer or at least 25kg, whichever is the higher.. For safety you should aim for, but not exceed, the lower of the 2 figures specified for caravan and car respectively.
Feb 28, 2009
493
Well I wouldn't believe everything you read.
Didnt Bailey have a University do tests which concluded 7% was the optimum noseweight for stability
909
4% is the legal minimum. There should be a plate or a sticker on the chassis frame giving details of the maximum. Unless it is a big exception, all current caravans, except some really big twin axles, have a 100kg limit, although this may already be more than the limit specified for the towcar. If that is the case, it is the car's noseweight limit that counts.
