Tow bar price
Sep 1, 2011
72
Hello. Have been getting prices for supply and fitting of a tow bar. Below is what I have asked for and price is there anything I have missed or questions I should be asking please. Vehicle is a X5 54 plate Detachable tow hitch Dedicated wiring loom Al-ko compatible tow ball 13 pin electrics Price £599 supply and fit, lifetime warranty in tow hitch and 2 years on the electrics. Any help would be appreciated thanks. Neil.
Oct 30, 2009
1,542
hi google X5 tow bars seek type you want double it for fitting and electrics should give you approximate cost, £600 seems a bit steep
but above all shop round
Dec 11, 2009
632
I would make sure it is FULLY wired electrics, i.e. fridge and battery charging wired up. A lot of dedicated wiring looms just have wiring for the lights.
Aug 20, 2009
159
I fitted the genuine towbar to my brother's X5 and it was a doddle. Took about 2 hours all in but does require removing the rear bumper and also cutting the lower lip of it.
If you were to fit yourself, rather than buy from BMW, go to Westfalia who make them for BMW. The detachable towbar is fully ALKO compatible.
Wiring kit is relatively easy as long as you can follow instructions. As well as the plug in part you also have to solder some piggyback connectors on to the CAN bus wires. Make sure they supply the socket which swivels up out of sight when not being used.
£599 fitted is not a bad price considering what has to be done TBH. I wouldn't have bothered getting the tools out for that money but back when I did it the going rate was almost a grand.
HTH. Dom.
Jun 11, 2012
1,525
28
19,685
Neil. just check your wiring in the back,with our X5 the wiring was there just had to add the wires for the fridge and of course a relay nice easy job and depending where in the country you are tryCDF tow bars.
Sir Roger.
Dec 7, 2010
214
18,585
/sites/practicalcaravan.com/files/images/sSig_hi_0.gif
Ordered a Skoda Octavia Estate 2.0TDi 4x4 in June, going to be built in November, delivery December!! Ordered a tow bar and electrics to be fitted.
Tow bar preparation, factory fit wires from fuse box through the canbus system and connectors at the rear of car (for road lights only) £125.00
Fixed tow bar £320.00 to be fitted by professional external fitter. Removable, a lot more!
Electrics 1. £95.83 (Skoda, with relays and heavy duty wire to battery for fridge and battery charging)
Electrics 2. £54.17 (Skoda, road lighting)
Total £595.00.
Bypass systems from tow bar companies, are a lot cheaper. To late now.
Jun 8, 2010
120
Had the Westfalia exactly as you described fitted by Indespension to my A4 Cabriolet 3 years ago for £350.Probably gone up now but worth asking.
Sep 1, 2011
72
Hello. Many thanks for all your responses. It it very much appreciated. And I now have some more questions to ask. Regards Neil
