I received an email from Western Towing today containing the information below regarding new tow balls. Is this true and should the black finish be removed? I have not seen any other information regarding this in any Magazines or from either of the caravan Clubs.
We are pleased to report that the towing industry is doing their bit for the environment. Previously all Towballs were zinc plated, a process which is highly polluting. Now Towball manufacturers have changed this process to a black powder coating and so have improved their carbon footprint. However, did you know .....
that this black powder coating paint finish must be removed before using the Towbar. The paint is chemical resistant so it's down to sandpaper and sheer elbow grease, we're afraid!
But don't be fooled because not removing the paint will cause you even more work, as the paint can ruin friction pads on stabiliser heads. Also the paint can make the towball slightly larger so it might not fit in your coupling head.
Chris
Chris
