Towing in four wheel drive or two
Feb 16, 2009
1,144
Can some one answer this question, on an early post it was said that Mitsubishi stated that when towing you should select 4H, l have been towing with my Shogun in "wheel drive.
Last Friday traded it in for a new SWB Shogun, while their asked the dealer what Mitsubishi recommended they said on tarmac two wheel drive, off muddy fields four wheel drive which is what l thought, can anyone show where MMS state when towing you must be in four wheel drive.
If the latter get ready for a big increase in mph
Nigel H
Apr 16, 2005
9
i have 3.2 d-id shigun and it states when towing put it in 4h
i asked the dealers about it and thay said it speads the load over both diffs....
Hi,
I tow with a 07 3.2 shogun and confirm that you should always tow in 4H. I have not noticed any significant increase in fuel consumption.
Nidge
Just to a d under the main heading of Towing in Four Wheel Drive or Two
It does depend on the vehicle and in this months PC mag a NIssan X Trail owner is advised to use 4WD on the road when towing
This is not what Nissan say and will Nissan say damage the transmision if 4WD is used other than in mud/snow/slippery conditions etc
The XT can be used in Auto which will detect slip and seemlessly engage $WD and slippry surfaces
OOPS 4WD
Feb 16, 2009
1,144
Gents thanks for your relies, picked up the Shogun yesterday read the manual and can confirm both Colin and Nidge are correct, manual states when a trailer is towed 4H must be selected.
NigelH
