Towing lights stopped working - only one indicator works, but is on all the time. I have changed the 12N socket on the caravan (2013) with a new one, but this has made no difference whatsoever! Not sure what to try next?
Welcome to caravan electrics.....Good idea - socket on car is new, so should be OK, I will test as you recommend & eliminate it as an issue.
I suspect there is an earth problem with the caravan, but not sure where to start looking.
