In one way I think it's a good idea to have sockets part of an MOT test. But I also share dusty's view about MOT testers being able to cope with 7 & 13 pin plugs and a suitable testing board. For example, My boat trailer has a simple lighting board which doesn't have a fog light. Whereas my caravan has 8 running lights, direction indicators, brake lights and fog lights.
Then of coarse there are direct wired systems. Those that are siply connected to the car's wiring directly. Plus there are rely and plc systems like the one on my Rover which do not use the power of the car's wiring loom except to switch the lights on. Basically what I have is a small plc circuit board which reads when for instance I indicate left on the car indicator switch, and then it switches on the lefthand trailer light to flash in unison with the car. (Well that's the simple way of explaining this).
One off shute benefit of this system is that when I plug in the trailer lights, the system works each set of lights on the trailer both singularly and in conjunction with each other. IE, you get sidelights, brake lights, side and brake lights plus indicators. This fully tests the trailer lights before you start towing and will not stop if it detects a failed bulb, therefore telling you of bulb failure.
Another plus with this system is, it is linked to the car alarm system and when a trailer is plugged inand the alarm is active, unplugging the 7pin socket will set the alarm off, thus protecting to some degree your towed vehicle.
When I first got my car the 7 pin socket was not working, so I contacted the manufacturer of the relay wiring kit to get a repair solution. Dusty has asked before about who the manufacturer was, but stupid me, I forgot to keep the details and the relay box where I got the name from is tucked away it the depths of the boot side panel which is a pain to get off. But when I next get to it, I will make note of the manufacturer and let you know Dusty.
