Trauma water connector
Jul 8, 2012
9
Hi could añyone advise me what to lubricate my water connector with please it is terribly stiff trying to push it in and j have just cracked the outer case on the caravan trying to get it out, you'd think I was using super glue to hold it, I'm going to crush the pistol grip the way I'm going
4,813
I use olive oil regularly. Just a smear on the fitting parts and the o seals
Sep 29, 2016
1,751
158
11,735
Martp,
It should not be that tight even without a lube, are you sure that the o-rings are of the correct size?
Someone could have replaced the original o-rings with ones that 'fit' but have a greater thickness.
Olive oil is fine, I use 'red rubber grease', it is a grease made from vegetable matter.
