Just completed 2 weeks holiday, on the 1st night of the holiday we succumbed to the blocked regulator syndrome. (thought we had escaped this as the van is a 2009 Sterling with regulator mounted fairly high and had assumed it was sorted!) However that was not the case. Despite very rarely using gas, and I don’t think there has been a bottle of gas through the regulator in the 2+ years we’ve had the van.
To get round the problem pig tails and regulator were removed and connected van up to gas via bottle top regulator (which have been good enough for us for 30+ years with no problems and still use for barbecues, etc)
Just enquiring really, has anyone else who has experienced these regulator problems (started 2004?) removed their bulkhead fitting and returned to the bottle top regulator? And if so any problems experienced? For I don’t particularly fancy spending £40+ on a replacement bulkhead fitting when I have several perfectly good bottle top regs available which are reliable. ( PS. I do know there is a marginal difference in pressure, between bottle top and bulkhead, but I can't think that'll bother anything).
