Truma gas/electric water heater
Mar 10, 2021
On my Bailey Regent caravan I am having problems on the gas water heater, works fine on electric.
On firing up gas the flame does not stay on after about 5/6 seconds it goes off tried a new circuit boarrd no better any idea,s would be appreciated
3,106
There is clearly some problem with the combustion side of the appliance.
But if you need to ask about what to do, then it suggests you don't have the knowledge or tools to safely complete the work.
If teh caravan is under warranty, contact your seller. Otherwise you should have a professional service engineer check it out.
For convenience you might find a mobile service engineer would be best. Check out the mobile guys on the Approved Workshop Scheme who are approved for such work.
Reactions: Jcloughie
936
First question: How old is the van?
Second question: When was it last serviced?
Third question: Was the outside cowl removed?
Reactions: ProfJohnL
